Help in S7-300 programming
  • Haogy1
    Haogy1
    Inscrit le 02/06/2023
    le 02/06/2023 à 08:53 Citer ce message
    Good morning.
    I'm Ismael, and I'm facing an issue with Ladder programming in Tia Portal using an S7 300 PLC.
    My program is supposed to heat a product up to 95°C and the maintain that temperature within 30mins before going to the next steps which is to cool down that same liquid within a range of 70 - 80°C.
    My problem is that i created a SCALE function and liked it to my analog pin and later on I used a comparator <95 to activate the steam valve the matter now lies at the level of the temporisation, though i used a TON to trigger the coiling system but it doesn't work as expected and it's getting me kind of nervous.
