OPC Client with Visual Basic and Csharp Sample code
- Le 16/07/2015
For connect a OPC client (Visual Basic or C # application) to an OPC server like KerperverEX, you should use the APIs or DLLs provided either by the controller manufacturer or equipment either by the OPC Foundation.With an OPC client, you can read or write tags,list OPC Server available etc..We will use KepserverEx and a Siemens S7-300 PLC simulated under PLCSIM.In the following video,you can see and HMI that communicate with a KepserverEX OPC Server.
S'inscrire à la formation sur les serveurs OPC :
automatisme supervision bus de terrain
